Simulation connections with Group Input/Output
I have defined a Group Input on my Virtual Controller, and have a Smart component with Group Output in my station. How can I connect them? In simulation options I cannot establish I/O connections with Group types (only DI or DO).
Using RS6.02
Many thanks,
Gabriele
Using RS6.02
Many thanks,
Gabriele
Hi Gabriele,
It is possible if you select "Add I/O Connection" in Station Logic/Signals and Connections:
Regards,
JohannesJohannes Weiman
It works. Thank you!!!0
