Robotstudio 6.02.01 Crash
JOEHOE
When you select the command "Set Position" and then you want to move that window to somewhere else then Robotstudio crashes.
Has anyone also having this issue?
Best Regards,
JOEHOE
Best Regards,
JOEHOE
How does it look if you expand 'Details' in the dialog?Johannes Weiman
Just checked and it crashes for me too.
Thanks,
That will be fixed in the upcoming release (6.03).
Regards,
JohannesJohannes Weiman
Thanks,
I see that this isue is solved in the new release of Robotstudio 6.03.
Regards,
JOEHOE0
- 365 IRC5
- 84 OmniCore
