How can I move in a sumulation a Queue of objects with the block MoveAlongCurve?
I am simulating the logic of a station with RobotStudio. For the moment I am moving an object with the block MoveAlongCurve, but I would like to move a Queue of objects as it is possible to make with the block LinearMover. Does someone know how to make that?
Some documentation about the block MoveAlongCurve would also be very appreciated.
Thank you
  • Not possible to use Queue with MoveAlongQueue
    Per Svensson
    Consat Engineering
  • MoveAlongCurve
    Per Svensson
    Consat Engineering
  • Thank you PerSvensson!
    Does someone know how I can move several objects following a curved trajectory? Are there some other blocks?
