Issues with creation of a station for M98A robot.
Luxrobotic
Hi everybody,
I have to build a station for a M98A IRB2400L.
But this output exists in the cfg file.
Maybe this problem is linked to the option "Advanced function" which should be installed in the VC, but I didn't found it in the configuration options.
Raymond
I have created the same I/O as in the robot controller, but I still have some analog output which is not recognized.
Error in the module :
Second issue, if I fix the first on by putting the rows “SetAO aoZone,nZone_1;“ in comment.
Raymond
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
the issue with the analog input is fixed. It was a wrong mapping in the signal configuration.
Now, still getting the second issue !
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
Did you restore a backup into the VC or just bring in the RAPID code?
Restoring the backup would cause issues as I presume a M98 system would be an S4C controller?
Try creating the VC from scratch then try bringing in just the RAPID code.
