how to update pickmaster in picking powerpack?
svoldgaard
I have updated my pickmaster from 3.44 to 3.51.
But the Picking powerpack still uses 3.44. Can I somehow change this without reinstalling everything?
Most probably, you do not need to reinstall Robot Studio or Picking PowerPac. You can just install Virtual PickMaster 3.51 on your PC and have it side-by-side with Virtual PickMaster 3.44. In the line tab of Picking PowerPac, you can select/change which version of PickMaster you want to run when simulating. Give it a try,
Best regards, Anders
5
