PickMaster Logfiles
Dear,
I'm looking for the place where the PickWare log files are saved on the controller.
The option is activated, see picture below.
When working with simulated pickers, using the Picking PowerPac, the files are saved under the following path:
C:\....\Solution\Systems\Picker1\HOME\PPATEMP
This folder (with the logfiles inside) only appears when the pickers are stopped, and disappears again when everything restarts.
But I can not locate the logfiles on a real controller. This PPATEMP folder is not created there.
Anybody that could help me with this?
Thanks in advance.
Willem
  • Hi Willem,
    on the real robot, from Rw6.01, the PickWare logs are included when you save system diagnostics. The PickWare logs can also be found on the ramDisk after stopping a PickMaster project.
    From 6.01 there is no need to check "Activate PickWare logs", they will always be generated.
    Anders
  • Thanks Anders,
    I'll check it when I'm on site again.
    BR,
    Willem
