How to use Integrated Vision
mvc
I'm a beginner using RobotStudio and I'm getting some troubles using it, especially using a System Vision. I've read the Application manual about Integrated Vision, but I'm still lost.
My problem right now is that I can't insert any snippet code in Program Module. First, I've started a virtual controller and enable the write access, as I've read in the Application manual.
Why is this happening? Could you please help me?
Thank you
Thank you
Can you discribe a bit more why you can't insert any snipped code. Is there no code available? Is the Program not active? How do you set up the virtual controller?0
- 365 IRC5
- 84 OmniCore
