TPWRITE
csoto
I want to write on the FPU using tpwrite and I want to write text, var text in the same line. Is it possible with this instruction?
Any help?
Any help?
Not sure what you mean but you can combine string variables to a complete text
Some examples
myStringVariable + " just a constant string"
myStringVariable1 + myStringVriable2
Per Svensson
Consat Engineering0 -
Thanks.
Both works!0
