To create a tool that can grip and release, I must create a mechanism and then convert it to tool?
I've created a simple tool in Solid works and I want to convert theses geometry in to tool, but I'd like  this tool could be simulated with two possition  : opened and closed. How I can do this??
Thanks very much.
Rafael
  • I think your tool is only one piece. Tool should be do with 3 pieces. I send you my gripper when I be at computer.
  • Thank you St4rk!
    I could not understand everything because it is in Slovak. I'll try to translate gradually.
    One last question
    Regards!!
    Rafael
  • Sorry but I am from Slovakia, but if you will have some problems, write a message.
