Problems with Unpacking and work!!!!
Hello,  I'm trying to open some .spag files, but the system shows me a message which says that the selected file is not a "pack and work" file.
Anyone have any idea why it happens????
Thanksss!!!
  • Hi,
    The file could be corrupt. If you rename it to .zip, can you open it in a zip tool?
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Thanks Johannes
    I've used winrar and the file is ok. Actually all pack & work files are showing the same problem.
    Regards
    Rafael
  • Is the file packed on the same version of robot studio as where you want it to be unpacked?
  • Some packages yes, others no. But I have installed several versions of robotwares.
