To create a tool that can grip and release, I must create a mechanism and then convert it to tool?
I've created a simple tool in Solid works and I want to convert theses geometry in to tool, but I'd like this tool could be simulated with two possition : opened and closed. How I can do this??
Thanks very much.
Rafael
Thanks very much.
Rafael
1
I think your tool is only one piece. Tool should be do with 3 pieces. I send you my gripper when I be at computer.1
Thank you St4rk!
I could not understand everything because it is in Slovak. I'll try to translate gradually.
One last question
Regards!!
Rafael
Sorry but I am from Slovakia, but if you will have some problems, write a message.0
