Robotstudio 6.02 with my robotware 5.14
i have an problem with robotstudio.
the robot system i have is an 4400 m2004 5.14.00.1032 but when i want to add an system to robotstudio it give an error with your robotware is not matching 6.02.
how can i fix this problem i need this to work this month and i cant find any updates for robotstudio with 5.14.
With kind regards
Martijn Ouwersloot.
The reason is that you need to download a matching robotware with your. Default RS 6.02 only install the latest RobotWare (Robot controller operating system). Go to the add-Ins tab and install the 5.14 versionPer Svensson
Consat Engineering0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
