TPWRITE
I want to write on the FPU using tpwrite and I want to write text, var text in the same line. Is it possible with this instruction?
Any help?
  • Not sure what you mean but you can combine string variables to a complete text
    Some examples
    myStringVariable + " just a constant string"
    myStringVariable1 + myStringVriable2
    Per Svensson
    Consat Engineering
  • Try this:
  • Thanks.
    Both works!
