How to use Task.CallRoutine()?
jeroen
I have developed a FlexPendant GUI application. I can get/set persistent values, inputs and outputs. But I cannot get Task.CallRoutine() to work however. Every time I call it, I get the error "SYS_E_EXEC_LEVEL: Operation is illegal at current execution level" or "[SDK.Rapid.CallRoutine] a task is executing".
I tried it in the foreground task, in a background task, in auto mode and manual mode but I cannot get it to work.
How do I use the Task.CallRoutine() function (if possible in a background task)?
Thanks.
Thanks.
The task which contains the routine, must be in "STOP" state, meaning that the program-pointer is set and the task is not executing.
If the program-pointer is not set, the error "SYS_E_EXEC_LEVEL: Operation is illegal at current execution level" will be thrown.
If the task is running, the error "[SDK.Rapid.CallRoutine] a task is executing" will be thrown.
So means you have to check in your FP-application what the state is of the task, for example this:PROC TestRoutine() ! Write message to TP TPWrite "TestRoutine executed..."; ! Terminate program -> loose program-poiner Exit; ENDPROCprivate void button2_Click(object sender, EventArgs e) { //Declare Variables Task tRob1 = null; Controller RobotController = null; StartResult sRes; try { //Get RobotController RobotController = new Controller(); //Get Task tRob1 = RobotController.Rapid.GetTask("T_ROB1"); //Check task-state if (tRob1.ExecutionState == ExecutionState.Started) { // Cannot call routine, because task already running GTPUMessageBox.Show(this, null, "Task running...\n Stop execution and try again...", null); } else { //When state is ready, the PP is not set -> reset PP if (tRob1.ExecutionState == ExecutionState.Ready) { tRob1.ResetProgramPointer(); } // Call the TestRoutine sRes = tRob1.CallRoutine("TestRoutine"); GTPUMessageBox.Show(this, null, "Call result...\n" + sRes.ToString(), null); } } catch (Exception ex) { // Exception handling GTPUMessageBox.Show(this, null, "Error...\n" + ex.Message, null); } finally { // clean-up task if (tRob1 != null) { tRob1.Dispose(); tRob1 = null; } // clean-up controller if (RobotController != null) { RobotController.Dispose(); RobotController = null; } } }0
