Exception when calling ABB.Robotics.Controllers.RapidDomain.Task.SaveProgramToFile
First I check all Controllers:
foreach (ControllerObjectReference controllerReference in ControllerManager.ControllerReferences)
Then all the Tasks  der Controller checked: (ABB.Robotics.Controllers.Controller)
var rapidTasks = controller.Rapid.GetTasks();Then the Modules should be saved:     { private readonly ABB.Robotics.Controllers.RapidDomain.Task_task;                               …       string f = "d:\\01_DATEN\\03_Temp\\" + _task.Name;       try       {         _task.SaveProgramToFile(f);       }       catch (Exception ex)       {         Logger.AddMessage("Problem saving file " + f + ex);       }                …..   }
  • The function "SaveProgramToFile" needs as argument the directory where the program will be saved. When using subdirectories, the definition for the path-separator is critical. In your case, you are using "\\" and this will throw an error in RobotStudio (I did not test on a real machine).
    See the following code for a working solution:
    private void button1_Click(object sender, EventArgs e)
        //Declare Variables
        Controller RobotController = null;
        string filePath;
        try
            //Get RobotController
            RobotController = new Controller();
            //Set directory
            filePath = RobotController.FileSystem.LocalDirectory + @/files_backup;
            foreach (Task t in RobotController.Rapid.GetTasks())
                // save to file
                t.SaveProgramToFile(filePath);
                // dispose
                t.Dispose();
            GTPUMessageBox.Show(this, null, "Saved in " + filePath, null);
            // Exception handling
            GTPUMessageBox.Show(this, null, "Error...\n" + ex.Message, null);
        finally
            // clean-up controller
            if (RobotController != null)
                RobotController.Dispose();
