RS 6.03 Crash after importing SolidWork file
Seems like there are alot of bugs in 6.03, It crashes when importing IGES and for some reason the CAD converter has been removed so we can even convert IGES to SAT.....
CAD Converter has not been removed from RS. It has been integrated. So now, whenever you try to import a file to RS, if you click on CONVERT TO ACIS, it will use CAD CONVERTER in background and no visible.Neily03 said:Seems like there are alot of bugs in 6.03, It crashes when importing IGES and for some reason the CAD converter has been removed so we can even convert IGES to SAT.....
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
