What is needed for using Integrated Vision?
I have a similar issue, is there any solution to this situation?Liberona said:Hi everyone,
Actually in my workplace, I have:
1.- An energized Cognex Camera model ism1020
2.- A laptop with RobotStudio 6.02.01 with a virtual controller.
My laptop has installed:
1.- In-Sight Explorer 4.7.3 software
2.- CognexDrivers.5.2.PR1-64bit
My virtual controller is built for a IRB1200 robot, with this options:
1.- [616-1] PC Interface
2.- [617-1] Flex Pendant Interface
3.- 1341-1/1520-1 Integrated Vision Interface
My issue is: Can I connect my Cognex camera via Ethernet, with my virtual controller? Actually all I can do, is - in RobotStudio Vision tab - to try to add a sensor, and RobotStudio succesfully recognizes my Cognex camera
and after clicking "Aplicar" (Apply) it shows me a login window. I enter user = admin and password = [blank] and later it shows a window saying that "My network setting are correctly modified"
This is the only option I have, in order to try to connect the camera, as the following image 3 shows:
After doing this, I don't have any option and my camera is not available.
Can I connect my camera this way? The IRC5 controller is actually in another place... a this moment I want to make the offline programming, only with the Cognex camera connected, but so far I couldn't.
Is there any option to programming offline with a real Cognex camera, connected to my virtual controller on my laptop? It would be great so I don't have to stay next to the real IRC5 controller.
Another option would be to use In-Sight Explorer 4.7.3 (with in-sight I can succesfully connect with my Cognex) and connect the x,y parameters via OPC server. Do you have any advice or experiencie doing this?
Thank you very much for your help.
Regards,
Pablo Liberona
Hi Pablo, when I moved the discussion you posted in recently from Developer Center to here, I see that you have really searched to forum and made several posts to get an answer to those questions. I worked with the development of Integrated Vision long time ago but I'm not up to date with the latest and probably I have forgot something about how it worked back then as well
I understand you are considering using Insight Explorer instead, but I'm really sure that your use case is a perfect fit for Integrated Vision. Have you bought the camera from ABB or from Cognex? If it is from Cognex you can verify with ABB support if it works or not.
In another post you referred to page 50 in the manual. Somewhere close there is instructions about configuring the controller (the VC) to understand how to establish a network connection with the real camera. Have you followed them?
In a real as well as virtual scenario you need to tell the controller that it shall connect to the camera. It is basically some CFG-settings that say that we have a camera on this IP and lets call it this name. That name is then used in the RAPID program when you refer to it from instructions such as "LoadJob".
When this step is done the IRC5 "knows about" the camera and it should be visible in the controller browser. When it is visible you can select it and connect.
Maybe this can help a bit.
Don't forget that you can contact your local contact person to get support and via him or her get help from the experts as well.
Dear Niklas,
Thank you so much for your detailed answer. I bought the camera from Cognex so I have to make sure if that model (ism1020) works well with Integrated Vision. I read that Integrated Vsion software development was tailored for Model 5000 Cognex cameras.
I followed the instructions from page 50 in the manual but it didn't work... the good news are I finally connected to the camera, using F1 help from In-sight Explorer 4.7.3 lol, in "How to.." --> Configure Robot Communications --> ABB Robot Controller. There is a code snippet that says:MODULE VISION
! DATA DECLARATIONS
PERS num nXOffs:=0;
PERS num nYOffs:=0;
PERS num nAngle:=0;
VAR string stReceived;
VAR iodev ComChannel;
PERS tooldata tGripper:=[TRUE,[0,0,0],[0,0,0,1]],
[5,[0,0,],[1,0,0,0],0,0,0]];
PERS tooldata tVision:=[TRUE,[[0,0,0],[0,0,0,1]],
[5,[0, 0, 0],[1,0,0,0],0,0,0]];
CONST robtarget pHome:=[[0,0,0],[0,0,0,1],
[-2,0,1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget pVisionPos:=[[0,0,0],[0,0,0,1],
[-2,0,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
PROC Main()
MoveL pHome,v1000,fine,tVision;
GetVisionData;
MoveL Reltool(pVisionPos,nXOffs,nYOffs,0\Rz:=nAngle),v500,
fine,tGripper;
WaitTime 3;
PROC GetVisionData()
VAR string XData:="";
VAR string YData:="";
VAR string AngleData:="";
VAR num NumCharacters:=9;
VAR bool bOK;
nXOffs:=0;
nYOffs:=0;
nAngle:=0;
Close ComChannel;
Open "COM2", ComChannel \Append\Bin;
ClearIOBuff ComChannel;
WaitTime\InPos, 0.5;
! Instruction In-Sight to Acquire an Image
! and not return until complete
WriteStrBin ComChannel, "sw8\0D";
CheckStatus;
! Get the value in cell C7
WriteStrBin ComChannel, "gvc007\0D";
CheckStatus;
! Read the X-offset
XData:= ReadStrbin (ComChannel, NumCharacters \Time:=5);
! Read the Y-offset
YData:= ReadStrbin (ComChannel, NumCharacters \Time:=5);
! Read the Angle-offset
AngleData:= ReadStrbin (ComChannel, NumCharacters \Time:=5);
!Closes Serial Channel "COM2"
Close ComChannel;
!Convert String Data To Numerical Data
bOK:=StrToVal(XData,nXOffs);
bOK:=StrToVal(YData,nYOffs);
bOK:=StrToVal(AngleData,nAngle);
PROC CheckStatus()
stReceived:=ReadStrBin(ComChannel,1\Time:=5);
IF stReceived<>"1" THEN
TPErase;
TPWrite "Vision Error!";
Stop;
ENDIF
ENDMODULE
Finally I connected to the Cognex Camera using telnet port, and modifying the upper code snippet... for example in the line " IF stReceived<>"1" THEN" I received the 1 digit in ASCII code, followeb by /RC (Return carriage) and /NL (New Line).
It was tricky but finally it helped to get some centroid data (x, y and theta)... according to my initial question, I haven't solved it but I found a not-so-fancy solution using telnet
Thanks for the advice of ask to a local contact person
Pablo Liberona
PD: Sorry for the delay in responding
- 365 IRC5
- 84 OmniCore
