Error Numbers
THOD
Okay, this has always got me. I trap my errors and find that sometimes I can only get the number, i.e. I just got an error and I know the ERRNO = 1002. How do I find out what that error is???
I also would like to know how to find out what the error is for a given error number.
And THOD, I am having trouble trapping my errors to see what the actual error number is, can you show me an example of your trap code?
Thanks for any help,
SM
you can use the "Program Data" window of the FlexPendant to show all data declarations for the errror numbers.- Open the Program data window
- Select data type "errnum"
- Click on the button "Change Scope" on the right side above the list view
- Select "Built-In Data only"
- Click OK button
- All error number declaration appears together with the error number in the list view.
- Now you can scroll down in the list and search for the desired error number
1002 : ERR_NORUNUNIT
BR
Micky
I had the same problem and used the FlexPendant to solve it, but I had to scroll through all of them because I couldn't sort by error code. Isn't there a faster way or a list somewhere else?
-Thomas0
