DSQC 652 trouble
Hello everybody
I have an application in wich I need to use I/O with a DSQC 652 in IRC5 compact. The module is well wired but I get an error message: 71367, No communication with I/O unit.
I've already tried all recommended actions but they don't work.
can anybody help me??
Thank you very much !!
regards
Antonio
I think your robot has devicenet option in the manipulador, so be sure that you have a "endresistor" at the end of the devicenet.
/Jorge
Jorge2013-01-08 09:39:33Jorge Turiel0 -
yes it was that, I was missing a resistor at the devicenet I figure out that yesterday :P while looking at the controller diagram , I had never work with robots before sorry, thank's anywayAntonio0
I am having the same error. I am using the newest edition of the IRC5 Compact. I just tried to map out my I/O device using Device_Net and I got that error. My Default address was 63, but I changed it to 10 and the error went away. Is this what I needed to do, or does the error mean something else?
The address of the first I/O unit (factory installed) is normally 10 - so changing the address from 63 to 10 would be the fix.0
Ok thanks Graeme!
- 365 IRC5
- 84 OmniCore
