Write access without mastership request
cncadmin
Hi All,
I'd like to transmit sensor data from a pc to a robot program. That should be working in automatik and manual mode without any response of an operator. Is it possible to get write access to a numeric ProgrammData without "grant"-ing write access to the PC for example in a background task?
Hope to find a solution.
Happy hackng
Benni
Happy hackng
Benni
Hello Benni
You can send digital and group inputs to the controller as a remote client, in manual and without mastership. So you can make your background task wait for a certain input and set your numeric variable according to the group input.
/Pavel0 -
Pavel,
(1) Can you define group inputs? (2) Can you provide an example of this using the PCSDK and manual mode? I'm working on a project wherein my targets will be continuously modified by sensor data, meaning each target will be offset (XYZ) based on what my sensor is telling me about its context. I have multi-tasking and pc-interface installed.
Thanks,
Nick
Pavel,
Can you provide an example of this using the PCSDK and manual mode? I'm working on a project wherein my targets will be continuously modified by sensor data, meaning each target will be offset (XYZ) based on what my sensor is telling me about its context. I have Multi-tasking and PC Interface installed.
Thanks,
Nick
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
