When recording a simulation for Station Viewer does not work.
When recording a simulation for Station Viewer does not work. You can see my video.
Case A) Record from the button Simulation-> Record to viever
It always creates a file dated 28/01/2013 and size 1006 KB empty of contents.
Case
Record from Share -> Save Station to viewer
Create a file containing the design of the station, but the simulation is not active.
Tested on different computers with 5.15.0 and 5.15.1
Finally a question: If it worked correctly Is there any difference between recording Record to Viewer and Save Station to viewer? What do you mean by "any recorded simulations"?
Here is the video:
http://db.tt/PgpkES0t
mp4 is not allowed directly in the forum.
.NET 4.0 is installed on my computer.
I've just tried it and it worked fine for me. Cool way to share simulations with customers.
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
- 88 OmniCore
- 42 AppStudio
