Connection to virtual controller using RobotStudio App
Is it possible to connect to a virtual controller using the RobotStudio App
FYI this is using a Windows10 tablet and virtual controller built with 6.03.01,
'Show virtual controllers' is enabled in the custom connection menu within the RobotStudio online manage app
  • Is the virtual controller running in the table also? If you are using the ABB RobotStudio Apps, it is not possible to connect to a virtual controller host in the same tablet. Can you describe the goal of your test, so there might be a workaround for it.
    BR
    Carlos Martinez
    ABB
  • Hi, The requirement for working with a virtual robot is so I can practice using / explore the apps away from the real robot.
  • A quick solution would be to have RobotStudio installed in another PC. Then you can make a virtual controller available to the network:
    https://forums.robotstudio.com/discussion/comment/13522/
    This is not a supported solution, but you can use it for practicing purposes.
    Carlos Martinez
    ABB
