Connection to virtual controller using RobotStudio App
sturner
Is it possible to connect to a virtual controller using the RobotStudio App
FYI this is using a Windows10 tablet and virtual controller built with 6.03.01,
'Show virtual controllers' is enabled in the custom connection menu within the RobotStudio online manage app
Is the virtual controller running in the table also? If you are using the ABB RobotStudio Apps, it is not possible to connect to a virtual controller host in the same tablet. Can you describe the goal of your test, so there might be a workaround for it.
BR
Carlos Martinez
Hi, The requirement for working with a virtual robot is so I can practice using / explore the apps away from the real robot.0
A quick solution would be to have RobotStudio installed in another PC. Then you can make a virtual controller available to the network:
https://forums.robotstudio.com/discussion/comment/13522/
This is not a supported solution, but you can use it for practicing purposes.
Carlos Martinez
ABB0
- 367 IRC5
- 858 RAPID Programming
