Track Motion IRBT6004 and IRB660 issues
Liberona
Hello everyone,
I've had some issues trying to create a system with additional axis.
It seems that IRB660 is not compatible with IRBT6004 TrackMotion, but I saw it working on a video:
https://www.youtube.com/watch?v=cBpmkFKqzg4
Is there any way to manually configure/enable the system? In order to the system allow this trackmotion?
In the Product specification FlexTrack IRT 501-66/66R/90/90R document, page 18, it says:
IRB660 is compatible with IRT 501 Track motion, but it just does not appear in RobotStudio libraries
How do I can download and load a IRT 501 RobotStudio library?? I found a document that tries to solve this, but the link to download the files are outdated...
https://library.e.abb.com/public/60c8fdd8134b2c1d482577ee001e5d07/How to load custom made libraries into Robot Studio.pdf
Basically I need to mount an IRB660 on a trackmotion no matter what model I'm using to.
I have 3 possible solutions:
1.-Try to succesfully configure IRB660 + IRBT6004 system
2.-Try download and load a IRT 501 RobotStudio library, into my RobotStudio
3.- (Less desirable) To make a custom track motion and find out how to make it compatible with IRB660
Thanks for any insight/help/solution you could give me. Best regards,
Pablo Liberona
https://www.youtube.com/watch?v=cBpmkFKqzg4Is there any way to manually configure/enable the system? In order to the system allow this trackmotion?
Pablo Liberona
Hello
I tested this combination using RobotStudio/RobotWare 6.03.02 and it worked fine. Update RobotStudio and try it.
/Pavel1 -
Thanks Pavel, I'll try it
BR,
Pablo0
- 367 IRC5
- 858 RAPID Programming
