FC Machining GUI doesn't work: FlexPendant Start View Problem
liaoifan
Recently I just received a brand new IRB 4600 with force sensor 660, I was trying to use the FC machining GUI, but it doesn't work, and the error code is 0xc0040603, and error message is more than 20 pages. After I acknowledge this message, it shows nothing. I've checked the forum and google for error code, still can't find a way to solve this. However, if I use the RAPID code example from FC Machining Manual, the FC Pressure works well, so I guess the problem is not about the hardware. Is there anyone know how to fix this? thanks a lot!
The attachment are the photos of the error information.
Here's the system data:
RobotWare version : 6.03.01.00
Control Module:
RobotWare Base
709-1 DeviceNet Master/Slave
603-1 Absolute Accuracy
616-1 PC Interface
617-1 FlexPendant Interface
623-1 Multitasking
661-2 Force Control Base
Control Module:
RobotWare Base
616-1 PC Interface
623-1 Multitasking
Hello
The problem is related to RW6.03.01. The latest FC machining GUI is not working with this RobotWare. A fix for this is under development.
Contact you local ABB for more info and status of the fix.
/Pavel
1 -
Thanks a lot Pavel, this information helps a lot!
Could you please tell me which is the latest version of RobotWare that FC Machining GUI can function properly?
Thank you again0 -
Hello
I hear that RW 6.02.01 works with the GUI version 6.01.
/Pavel1 -
Thanks!
The problem had been solved by downgrading the version of RW.2
- 361 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
