Integrated Vision with ism1403
Hi everyone. I'm facing a problem while trying to connect ism1403 camera to robotstudio. I know that camera is supplied with PoE. Camera and robot controller are in the same subnet. I can only "Add sensor" and after that nothing happens.
Waiting for Your suggestions.
I tried InSight 7000 series camera. It worked perfectly and I don't know why I'm facing problems using ism1403 camera.0
Is the ism 1403 part of the insight series of camera?
As I understand it Integrated vision only work with the insight series.
Yes, it's In-Sight Micro series camera. As ABB claims, any of In-Sight series camera can be used with Integrated Vision.0
- 367 IRC5
- 858 RAPID Programming
