calcuale midpoint of arc
Does anyone have a routine or function that will calculate midpoint of an arc, given the 2 end points? One of my paths contain an arc. I want to break the arc into 2 segments. The midpoint of the original arc will now be the end of the 1st arc and start of the 2nd arc. However, I only want to teach the 3 points of the original arc and calculate the additional midpoints. Instead of having one MoveC, I will now have 2 MoveC's consecutively. The 3 points from the original arc is enough information to calculate everything else, I was hoping someone has already done the code, or something similar.
I have one but it's only good when the orientation of the points are on the same plane (same Z direction).
Not quite sure how to interpolate quaternion orientations.0
- 367 IRC5
- 858 RAPID Programming
