Changing deviation alarm parameter with rapid on the fly.....
I'm wanting to change the parameter of a deviation alarm using Rapid code but I can't find anything that covers this in the manual.
The parameter is   -  -path "A1FluidDev/Notify" -value 1
I'd like to be able to change it through a rapid program on the fly as the robot is running, I can do this through Robview no problem but I want the robot to be able to set the value to "1" incase it is manually set to "0" and forgotten about....
Any ideas?
Thanks.
Neil.
