in RW 6 not able to define virtual bus or virtual I/O board
Hello to all, since we switched from RS 5.60 to 6.00 we are not able to create virtual signals in RobotStudio, why is this. Thanks.
  • hello,
    in rw6 you dont have to assign virtual signals to a virtual board, just leave it blank.
  • Thanks Peter, I'm trying to use backup from S4C+ in RW 6, actually EIO.cfg
  • Not so easy any more - the format of the EIO file has also changed with RW6.
