External Axis Wizard 6.01 is available
The external axis wizard for RobotStudio 6.01 is available from RobotApps,
https://robotapps.robotstudio.com/Details.aspx?fileId=fc5a49c6-b1ea-454c-a271-a33bcf26049c
Kind regards,
ABB
ABB
Post edited by Pavel Riabichev on
Is it not working in Robot Studio 6.03? I am having problems using your video tutorial of youtube when I try to create the system from the current design.
https://www.youtube.com/watch?v=CffgcZrR7VI
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
https://youtu.be/iJ5pMgLuTFU
the XZ lifter only sync with robot path at the auto configurations
if i simulation this path then fail.
is there any problem with the setup?
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 31 AppStudio
