Filter Active on Simulated Signals
Does anybody know if Filter Active and Filter Passive not working on simulated signals is a bug with 6.03 baseware?  No matter what I set the value to on Filter Active "5000" the signal comes on immediately no delay.  I am seeing the same results in RobotStudio as well.
  • Micky
    Micky ✭✭✭
    it is not possible to use a filter for simulated signals.
    /BR
    Micky
