AddIn Packaging tool
Has anyone managed to create a RobotWare AddIn using the AddIn packaging tool? I have created a project, created an Install.cmd file, put everything in the directory structure as shown in the documentation, but it just wont work. The option I created appears in the installation manager, it is selectable and appears to be part of the system I am creating. However, when I boot the robot (Virtual), none of the files are loaded, none of the directories are created and none of the files I have set to copy are present. When I build the package the install.cmd file disappears?
Any ideas, or if anyone has managed to create an AddIn, could your share your pre build project with me?
Thanks in advance. / PC
-1
where can I find documentation about this?
And did you get it to work?0 -
You can find tutorials here:
http://search-ext.abb.com/library/Download.aspx?DocumentID=9AKK10103A0857&LanguageCode=en&DocumentPartId=&Action=Launch
