Suggestion: Default folder when saving modules
It would be nice if the current system folder opens when clicking "Save module as". Or a button to go to the system folder when the save window opens.
When working with several solutions at the same time I usually do this manually by clicking "Open system folder", copy the folder location, close window, "Save module as", paste folder location of the system and then find the correct sub folder to save in.
In 6.04 its even worse, the default path when saving is always the same, in my case an old backup.
/David0 -
You should have several shortcuts in the save dialog, one of which points to the system HOME folder:
Johannes Weiman
Nice!0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
