TCP Trace in RS 6.04
The ability to trace the TCP when running programs from the virtual Flex-pendant or Rapid editor only, seems to be removed in RS6.04... this is a real shame ! is there any way to achieve this... tried to turn on and off, TCP trace with events but no success.
Any thoughts?
  • Hi,
    The new TCP Trace uses Signal Analyzer functionality and is therefore only available with a simulation.
    But if you check "Free run" and uncheck "Automatically start execution.." in Simulation Setup, you can control RAPID execution yourself during simulation.
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Hi. Yes I am aware that I can play the program independently using the FP or Rapid editor.
    During robot training courses we like to show our students the TCP trace. I will therefore have to keep RS6.03 installed as the Virtual FlexPendant is used during demonstrations.
    Kind regards
    Simon T
    Senior Training Instructor
    ABB UK
  • Is the workaround above not adequate? Why?
    Johannes Weiman
  • I have tested the suggested work-around of using 'Free-Run' but this still does not allow the trace to appear when operating the program from the FP.
    Because my training stations use Smart components, I deliberately exclude the virtual controller from the simulation.
    I did wonder if it may be something to do with the TCP being connected to a Smart component but  even  tool0 do not work either.
    Kind regards
    S
    The controller must be included in the simulation for TCP trace to work. But I don't think a controller in free run with automatic start disabled should interfere with your smart components?
    Johannes Weiman
  • To Trace when using the FP, I have to do do the following in simulation setup,
    Check Virtual controller,
    Un-checking 'Automatic start of selected tasks'
    Select the tool in the station that I want to trace with,
    Start the simulation,
    Switch contoller back to manual...and now traces when jogging etc.
    Got there in the end ;-)
