installation of the system for IRB2400 irc5
Hello!!!
For ten years has worked without problems robot IRB2400 irc5. But here the problems started, started a reboot, as it turned out ,the reason was the Compact Flash , I decided to make the image Flash during the copy process was a read error, now when turning on the robot, a window opens with the initial installation of the system, with four tabs, install system, settings option. And another two, but we don't have the installation files, tell me where I can take them, and the installation procedure of the system
  • Maybe your flash image is damaged, these cards are protected so you cannot make proper image of them (hidden boot sector). Best would be to contact local ABB with robot's serial number and ask for new flash card(with your system), they are not expensive.
