TCP Trace in RS 6.04
Any thoughts?
The new TCP Trace uses Signal Analyzer functionality and is therefore only available with a simulation.
But if you check "Free run" and uncheck "Automatically start execution.." in Simulation Setup, you can control RAPID execution yourself during simulation.
Regards,
JohannesJohannes Weiman
Hi. Yes I am aware that I can play the program independently using the FP or Rapid editor.
During robot training courses we like to show our students the TCP trace. I will therefore have to keep RS6.03 installed as the Virtual FlexPendant is used during demonstrations.
Kind regards
Simon T
Senior Training Instructor
ABB UK
Is the workaround above not adequate? Why?Johannes Weiman
I have tested the suggested work-around of using 'Free-Run' but this still does not allow the trace to appear when operating the program from the FP.
Because my training stations use Smart components, I deliberately exclude the virtual controller from the simulation.
I did wonder if it may be something to do with the TCP being connected to a Smart component but even tool0 do not work either.
Kind regards
S
Johannes Weiman
To Trace when using the FP, I have to do do the following in simulation setup,
Check Virtual controller,
Un-checking 'Automatic start of selected tasks'
Select the tool in the station that I want to trace with,
Start the simulation,
Switch contoller back to manual...and now traces when jogging etc.
Got there in the end ;-)0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
