How to Set Up I/O on an ABB Robot with an IRC5C Compact Controller
baijun
Hello!
My robotware version is 6.02, and robotstudio is 6.03, these two versions can work. now configuring the generic IO can not find the so-called Device item in manual, and the existing tutorial is not the same.Do anyone know how to do it, thank you very much.
Sorry, I found out the problem is that I accidentally removed the DeviceNet option before.0
- 367 IRC5
- 858 RAPID Programming
