Issue while Synchronize paths to Rapid
Luxrobotic
Hi everybody,
sometimes, I have a problem when I synchronize to Rapid.
The synchronization freezes at 48 or 50%, It's not possible to finish. I need to cancel it, close and restart RS.
I use RobotStudio 6.03.01 (64-bit)
Version 6.03.6983.1035.
Thanks for your help.
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
Hi everybody,
any idea ?
I've got the same issue yesterday with the last release of RS.
Thanks.
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
now I've also got one time the same while trying to synchronize to the station.
Rgds.
If it freezes for me when syncing station > rapid. I know there is an issue with the motion of the robot. I fix the path, autoconfig, make sure all targets reach, etc then resync.0
when it freezes and I restart RS, I can directly sync the path to rapid, without making any change, and it works.
In many cases, my paths don't have any motion issue (Reachability or config are ok), and the bugs occures.
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
