Synchronization failed from station to RAPID
Hi Team,
since several days I have the problem during synchronization from station to RAPID that the creation of paths in T_ROB1 is failing for certain paths. Depending on the program the synchronization fails for 20%, 50% or 80% of the paths.
The synchronization from RAPID to station works without any issue.
Thanks for your help.
Best Regards
Marcus Riedel
Robotstudio 6.04
RobotWare 6.03
If you are failing when syncing from station to rapid, there is probably and issue the motion of the robot. Make sure you auto configure and all targets reach before trying to sync.
Note: when syncing from station to rapid, I typically like to do it one path at a time. RIght click the path in the (home > paths&targets > path) and click sync to rapid.
