How to use the RAB controller console window?
Jerome1
In the RAB User Guide they talk about the controller console window where we can write command like fpcmd "-restart" to debug our FlexPendant application. Can someone tell me how to use it? Where can I find that controller console? I don't find the information in RAB User guide.
Thanks,
Jerome
Thanks,
Jerome
Hi Jerome,this topic constains a zip with two documents, where one describes how to connect your PC to the controller console.0
Hi Niklas,
The link is not working anymore. Where can I find the two documents?0 -
Sorry I totally missed your question. I cant find the documents that I linked to 2009.With RobotWare 5 you use a serial cable and a serial terminal program on your PC to connect and type in the commands. With RobotWare 6 you need to use a SSH client.
I'm moving this post to the RobotWare forum.
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
