PC SDK and RS232
samosamo
Hi everyone,
I would like to ask if PC SDK allows connection through the RS-232 protocol. I know that it is possible to do it via ethernet but in this case PC Interface is needed.
Best regards
Samo
Best regards
Samo
Hi Samo,
PC SDK can only communicate over TCP/IP over Ethernet.
Robot Web Services does not require PC Interface. Have a look at Developer Center.
