Robot studio 5.14.03 not getting a license from new SLP server.
I had this issue before and installing 6.03 on the PCs fixed the issue, but this no longer seems to fix the issue.
I have 3 versions installed on my PC ... trying to fix the issue and versions 5.61 and 6.03 can both obtain a license with no issues
but 5.14.03 says "Network license not available"
RobotStudio .NET exception: Canceled
Base exception: NotLicensedException
Canceled
at Microsoft_Licensing_Permutation_6e3db_2_0_3_1_1925_4kh.A(Assembly A_0, Byte[] A_1, IExecutionEngineParams A_2, Boolean A_3)
at Microsoft_Licensing_Permutation_6e3db_2_0_3_1_1925_4kh.A(Assembly A_0, String A_1, IExecutionEngineParams A_2)
at Microsoft.Licensing.SLMRuntime.InternalExecuteMethod(Assembly declaringAssembly, String SVMMethodId, IExecutionEngineParams paramsReader)
at Microsoft.Licensing.SLMRuntime.ExecuteMethod(Object obj, String SVMMethodId, String _assemblyId, Object[] args, Type[] genericTypeParams, Type[] genericMethodParams)
at ABB.Robotics.RobotStudio.LicenseValidator.AcquireExecute()
at ABB.Robotics.RobotStudio.LicenseValidator.Initialize()
any help would be appreciated.
Regards,
Neil
I am running Windows 7 Enterprise on my PC0
the old server had SLP version 3.2.1965.6 the new has 3.2.1986.18, no that does not seem to matter either.. I can not get it to work off that version anymore..0
- 303 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
