Defining new RAPID instructions and appending code to an existing module
Hi!
I have just started working with the RobotStudio SDK so my knowledge is quite limited. At the moment, I try to figure out what are the possibilities and limitations.
What I want to design is the combination of an addin and a RAPID library that is used together. The addin is used to autogenerate some code (including robtarget and procedures) that results in a module file (.mod) which is synhcronized to the station and executed on the robot. The procedures are defined in my RAPID library.
In that respect, I have two questions:
  1. Is it possible to define and compile new "core" RAPID instructions based on code written in for instance C#? The reason I want to do so is because my RAPID library is going to contain some mathematically cumbersome functionality requiring linear algebra and the like. This would be a lot easier to implement if I could make use of existing linear algebra libraries implemented in .NET or other frameworks.
  2. What is the best way of writing robtargets and PROC-calls to a module file using C#? Lets say I have an existing module file called mymodule.mod that I want to append
    some robtargets and PROC-calls to.
Best Regards,
Andreas
