Hi All - ! IRB_140_6kg_0.81m (Station):10068 - Start Program Simulation Fails to run
IAN
When I try and run my program in simulation mode it displays ! IRB_140_6kg_0.81m (Station):10068 - Start Program Simulation Fails to run
Double click on this and pop up box 10068: Start Program Description Unable to start program for task T_ROB1
Make sure that 1) you have synchronized the program to the VC, and 2) the entry point is correct in Simulation Setup.
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 31 AppStudio
