Collada Add In Export Error
everytime I try to Export a Simulation in RobotStudio with the Collada Add-In, the process stops and I get this Error Message:
RobotStudio .NET exception: Exception of type 'System.Exception' was thrown.
Base exception: Exception
at RobotStudio.Services.GraphicConverters.Collada.ColladaExport.ProcessAnimData(SimRecording recording)
at RobotStudio.Services.GraphicConverters.Collada.ColladaExport.Export(String fileName, ProjectObject root, SimRecording recording, Boolean skipInvisibleObjects)
at RobotStudio.UI.Simulation.SimulationControl.<Simulator_StateChanged>d__9.MoveNext()
The Solution is quit big (~500MB), but I have also tested some Demo-Solutions and they also do not work.
The Message appears after the Add-In wants me to save the File!
RobotStudio Version: 6.04.01
Collada Version: 6.03 (downloaded from ABB Add-In Website)
Does anybody know this Error or has an idea what could be the problem?
Thank you for your Help!
Bernhard
Bernhard
Hi Bernhard,
It seems the Collada code is incompatible with a change in the internal simulation structure.
Unfortunately there is no workaround other than using an older version of RobotStudio. I will make sure this is fixed in the next release.
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics0
