RobotStudio v5
josedias
Can someone tell me where i can download robotstudio version 5. kind regards, José Dias
The current version of RobotStudio will connect to a controller running RW5.xx, and you can create virtual controllers for RW5.xx as long as you download & install the RobotWare (go to the Add-Ins tab in RobotStudio) .
The current version can be downloaded from here http://new.abb.com/products/robotics/robotstudio/downloads
Thank you,One more question. I already installed the RobotStudio 6.04, and RobotWare 5.15.But for now i'm learning to use the RobotStudio, i already have experience programing "real robots". The robot i'm working it's an IRB1400 and the controller it's the S4C. In your opinion i can connect, i mean syncronyze booth using the current configuration, RS6 and RW5? Or i need other version of RobotWare?Best regardsJosé Dias0
Unfortunately you can not connect to a S4 series controller with RS5 or RS6.
You could create a virtual controller with the equivalent options to your S4 controller and load the RAPID modules into that for editing.
After editing save them to disk and load back into the controller (be careful not use any commands that are not available in the older version of RAPID).
Thank you,
I will pay attention to the commands,
José Dias0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 31 AppStudio
