Graph and plotdata in flexpendant sdk
I'm trying to dynamically add plots to my graph. How do i resize the plotdata array from the code?.
  • Did you define the array in the C# (or VB) code or in the Rapid code? In case of Rapid, you can delete the array and create a new one with a different size. If needed, i can give sample code for that
