Collision Set and Conveyor Tracking.... Still doesn't work...
I was hoping this would be fixed with an update but in 6.04 Collision Set still doesn't work with conveyor tracking, as the object on the conveyor or now link since 6.02/03 they can't be added to a collision set, you can only add the original Geometry which a couple of months back led to a real life collision which could have been very expensive.... When can we have a fix guys??
I have reported this to our team and they gonna fix this.
/Adnan
There is a solution to creating collision set with conveyor tracking or you could call it walkaround and its creating smart component.
So you have build your station and if you go to Simulation tab and chose Station Logic then Design there you can right click and under Sensors chose CollisionSensors where you can define object A as the robot tool and object be as whatever the tool comes in contact with.
Hopefully it helps!!
/Adnan
- 367 IRC5
