Palletizing PowerPac required Inputs and Outputs
Are there default IO configuration files available for use with PM5 system using the Palletizing PowerPac.
This seems to be a fundamental requirement when using the above.
  • Signals now loaded !... System did not load PM5 Option, worked on 3rd attempt, strange?
