Cannot add Multitasking option to IRB
kazoo
I’m trying to use Multitasking on IRB. I’ve already tested on Virtual Controller and worked well.
Then, when I tried to apply it to the actual controller, I had an issue and I need support how to use Multitasking.
When I tried to add New Task from Configuration -> Controller -> Task, it doesn’t allow me to add another task.
I guess this is because of the lack of Multitasking option, so I tried to add that option from Installation Manager.
Unfortunately, it didn’t show anything about Multitasking option, so I couldn’t choose it.
I also tried to “add setting” file from the working Virtual Controller, however, it said, “Option(s) in settings file requires license or product”.
I’m sure I already have a premium license for the RobotStudio. Do I need to get another license (maybe for Robot Controller?) to use Multitasking option? If not, please let me know how I can use it.
Yes, you need to acquire a license for the robot controller. Your local ABB representative should be able to help you.Johannes Weiman
Thank you so much. Do you know how much the price is?0
Not the faintest idea unfortunately
Johannes Weiman
RobotStudio Team, ABB Robotics1
